Replaced timing belt and now odd idle.
Thanks for looking at this post. As it reads monday I had my timing belt and water pump replaced on my 1995 Honda Civic D15 16 valve. Immediatly after I noticed the ide was different, instead of being constant as it was before the service was it seem to go very low and go up a little bit and back down but the engine seems to vibrate instead of just idle. I cant explain it but its there. The gearheads at my work says he may not have lined up the gears when he replaced the belt. I have tried to reset the ECU, check the coolant level, spark plugs and wires seem fine. If you have any ideas as to why this is happening please let me know ASAP as im taking it back in tommorow morning.
Re: Replaced timing belt and now odd idle. (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 »</TD></TR><TR><TD CLASS="quote">The gearheads at my work says he may not have lined up the gears when he replaced the belt. </TD></TR></TABLE>
UUmm yeah, take it back, and DON'T let that guy touch your car............ever. Try lining everything up to TDC and make sure everything is lined up; ie: crank pulley, cam gear, etc. If everything IS lined up, try doing a valve adjustment and see if the noise still persists
Re: Replaced timing belt and now odd idle. (JDMH22HATCH)
well it doesnt so much make a noise as it surges at a low idle i guess, I hate that I dont know how to explain I just know its not the same, I have searched this site and have taken all the old advice into account but its still there.
Re: (Malakai)
thanks so far, more of what i was thinking thats a plus. I just bought this car and not to bad so far, this just pisses me off all excited about getting a nice car then this crap happens. If anyone reading this has an idea about what it could be post it.
Location: everything for everyone, and nothing for ourselves
f*ck*d up idle 'eh?
take it back to the mechanic bro ... they made the problem- they fix the problem.
Re: Replaced timing belt and now odd idle. (censurebush)
everyone saying misaligned timing belt... check it out and let us now if thats it...
good luck
good luck
Re: Replaced timing belt and now odd idle. (esohsee)
timing belt is off a tooth on the cam gear(s). line the crank up to tdc and see if the cam gear(s) are lined up correctly.
Re: Replaced timing belt and now odd idle. (93delslo)
you were all right thanks alot guys she purs like a kitten.
RockLee`
11
02-02-2007 10:03 PM
