Check engine Codes
Check engine Codes
Hi everyone i need some help with my honda i have run ignition ant checking check engine codes i got 7 ,22,41 i got information what that codes meens
7 - TPS - throttle position sensor
22 - VTEC pressure valve
41 - Primary oxygen sensor heater
but dont have any idea how to fix it can some1 share they experience and help my solve this out ,
7 codes i ges its because one of connector are broken
but what can by with 22 and 41 codes pls help my solve this
Re: Check engine Codes
more times then not if you're getting 41 just replace the 02 as for 22 vtec ps look at the FAQ sticky up top show a flow chart on how to test the it. 7 check the the tps is getting the correct voltage for starters.
it was when i buy this car , i ask about working with Z6 on other forum and one smart guy says that they are very similar and they shoud work . There is one of connector broken who gives 7 error code dont know mabey there is ware start all other errors because now he is no connected
Amorous
03-14-2009 04:47 AM
serious
04-06-2003 06:07 PM
