Omni power vs oem clutch master cylinders
So when I first got my car I was told the b16 swap was stock with a new clutch which I was also told was stock so my problem is I replaced the the clutch master one because I though age but then I blew through another one and another one after that so my question is it worth buy the omni power clutch master cylinder since I would assume that it's more heavy duty? Or keep replacing the stock ones? Btw the car is a 97 civic hatch thanks!
Re: Omni power vs oem clutch master cylinders
I just installed my omni power CMC the other day. Pedal is pretty tough haha. I suggest s2k CMC.. From what I was told they're the way to go.
the omni one is NOT more heave duty it just makes the pedal travel considerable shorter so you can "shift faster". just go OEM Honda or the s2k route but again OEM Honda I wouldn't run it on my track car not worth it. Why are you burning threw CMC's ?
yes^ it's NOT plug n play tho https://honda-tech.com/forums/acura-integra-6/how-s2000-clutch-master-cylinder-into-dc-eg-2830117/ I considered it but was to much work for the gain imo.
alaskanlue
07-11-2015 01:31 PM
lazii_boi08
11-27-2009 11:38 PM
turboedsupe
06-07-2009 05:56 PM
