civic choke and sputter when press gas
hi, My 97 ex choke and sputters when press the gas when the engine is cold, if I wait until it reach operating temperature I can drive it but with a choke at take off then rev's fine always you not make a WOT pull.
No CEL!!!
LS VTEC
No CEL!!!
LS VTEC
Re: civic choke and sputter when press gas
I forgot that the car always start the first time, now it dies the first time start it again and stay in normal idle.
ECU P06 chipped and vtec converted. (tested in other car fine)
Fully build block
JE 9.0:1 pistons 81mm (tested last week 200 across the board)
Eagle H rods
Sleeved
B16 head port and polish, Supertech valve train. ITR cam IN/ GSR EX.
Precision 650cc saturated injectors (12.8 ohms in 3 of them and one 12.6)
Walbro 255 Rewired (lately the sound change to louder) maybe I'm paranoid.
New fuel filter
New Dizzy
New fuel regulator (AEM). This was my first suspect the old B&M.
Switch TPS .46 - 4.58
Yes the CEL stay one 2 seconds and turn off, if I unplug any sensor the CEL pop on and i can read the code. I'm making this tests with the engine pressurized and not and the same.
Fully build block
Eagle H rods
Sleeved
New fuel filter
New Dizzy
Yes the car is dyno tuned and work perfectly for 2 years without problems.
Not my daily and good maintenance.
When I put the new dizzy I set it with timing light.
The cams and crank are in spot. But really weird the car sometimes rev's like it is retarded ( very sluggish/laggy).
street_racer_271
06-11-2012 07:53 AM
RDAYA0
20
04-08-2008 08:56 PM
FlatTire
12-10-2004 09:00 AM
n8barton
06-16-2004 10:45 AM
