Hit a Pothole... need help
The Story
6:30 this morning i was driving from home to school, and came around a big turn. Some douche was half way in my lane so i drove over the white fog strip and just as i glanced down. BOOM. Big *** pothole engulfed my front passenger side wheel.
The Problem
Obviously you can expect the wheel to be somewhat damaged. And it is slightly bent. But the thing that gets me is when i turn to the right, 90 degree turns or more, the car clicks in the back passenger side of the car.
I appreciate any ideas that you throw at me. Im deffinately going back there on my way back home and taking pictures of the monster hole, and getting money from the state. F Michigan roads
The Problem
Re: (All-Out Motorsports)
i have hit a pothole the same way with my car, i dont know if i have a bent wheel or what, my whole steering wheel shakes tho.
is all you get is a click? if so it definately sounds like cv. maybe its ur ears playing tricks on u thinking it is the rear?
good luck with that
good luck with that
Yeah I think it's probably your ears playing tricks. If you hit with your front passenger side wheel it would most likely be that wheel that's damaged
Check the CV joint like the others said. That's usually what causes clicking.
Ok... now if it does turn out to be... can i use the cv joint off of my friends 94 teg. My hatch has a b18c1 swap in it... im pretty sure it will work... hes wondering if it will work because his is an auto and mine is not.
r3000
12-20-2004 09:29 AM
zizux
08-28-2003 01:11 PM
