is this normal
Old 10-04-2005, 01:49 AM
wanabericer's Avatar
Default is this normal
ok i have a gsr with the basic bolt ons, fuel mods, cams, ect......and before my cars idle drops after rev to almost to 100 rpms so i cleaned my IAVC crap and my car idles way better but it still dropsafter rev but not as low as before.......it drops to 500 then goes back up and idles at 6-7 hundred so is this normal????i know i'm a noob just a simple question
Old 10-04-2005, 03:36 AM
delsoldrew's Avatar
Default Re: is this normal (wanabericer)
does it do it when your radiator fan cuts on? if so thats normal.
Old 10-04-2005, 05:35 AM
.Ry
.Ry's Avatar
Yeah mine does this. The engine slows way down but then catches itself almost? Your idle should be about 700rpms + or - 50. As long as it comes up to 700 or so and stays your fine.
Old 10-04-2005, 05:38 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wanabericer &raquo;</TD></TR><TR><TD CLASS="quote">before my cars idle drops after rev to almost to 100 rpms so i cleaned my IAVC crap and my car idles way better but it still dropsafter rev but not as low as before</TD></TR></TABLE>
I'm thinking your IACV may still not be 100% I've never had luck with cleaning them. My idle is pretty solid at 700, except for when the A/C or cooling fan kicks on.
Old 10-04-2005, 05:45 AM
blaze the chemi's Avatar
Default Re: is this normal (AutoXer)
I would check to see if your idle is stable. Do the stuff according to the Helms and maybe you need to adjust the screw on the throttle body. But your idle concerns seem normal. Just check it out and make sure the IAC is within working parameters.
Old 10-04-2005, 05:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
mines drops alittle more when ac's on too but i think thats normal.........thanks everyone......
Old 10-04-2005, 05:41 PM
junior40er's Avatar
yup mines does that. Its not a issue. I hit the throttle and then it'll go to 700rpm before idling at 800RPM
Old 10-04-2005, 07:28 PM
civic_driver's Avatar
mine drops after i sit 30secs to a minute at a red light with brake pedal pressed
it drops to about 500 for about 2 seconds then goes back up...what you guys think?
btw, my major idle problems improved when i did my valve adjustment and cleaned the grounds
now it does it only as specified and that's after i've driven the car for about 15-20 minutes.. could it be from the radiator fan? why does it do that though? is it to help coolant recirculation? is it possible to not drop the idle when the radiator fan kicks in? if possible i'd like to make it run smooth and if i need it cooler, i'd put a different radiator and a different thermostat
Paprika
05-08-2007 03:18 PM
1sikhatch
11-30-2006 09:55 AM
93JDMB18C
11-02-2006 02:03 PM
jerbear!
05-09-2005 11:00 AM
Quick Reply: is this normal
