D series skunk 2 manifold?
So I bought a manifold for my y7 motor...its the skunk 2 pro series...what all do i have to change to bolt that on to my car...do i use the the same throttle body? are alll the sensors the same? where do the different hoses run to? thanks any one that has done this before could be great help to me....
Re: D series skunk 2 manifold? (Koyoloeor)
c'mon i know someone has to have done this....i thiknn i use my stock throttle body but i thought that the throttle cable was different..not sure..any help would be great! thanks
it didnt bring installation instrutions... im thinking it would be similar to doing a y7 to y8 manifold swap.... Trying searching that up...
Re: (chinese acrobat)
no no instructions included...i have it hooked up right now..the hoses seem to be fine but i currently have a b18b throttle body on it and i know that it is wrong because check engine throws all the codes....i was told to use my stock throttle body but it seemed to me that it wouldnt work because of the way the throttle cable hooks up...its almost oppisite the way i need it to be..not sure really....thanks for the help
Re: (sohc_boy)
so i have everything good now and i put the y7 throttle body back on the mani....now my problem is that my idle surges...i scaned my check engine light today at work and none of my sensors are bad..cuz i thought either map or tp sensor went bad, but aparently there not...any suggestions??
Re: (Koyoloeor)
how did you make your y7 throttle body work?, also, are there cia holes on your im, caz that will make your idle surge, to fix it all, just get an auto y8 complete throttle body and you will be set
hovic
08-27-2004 01:10 PM
JforJonathan
10
04-10-2004 12:15 PM
