GSR rear sway bar...bolts on to EK hatch?
Does a GSR rear sway bar bolt straight on to a 2000 hatch? Does it need some modification---what does it need?
If you know, please share before I buy!
Thanks.
Thanks.
Re: GSR rear sway bar...bolts on to EK hatch? (fireant)
if you have the gsr endlinks you can use those or si ones will work and you will also need to go to honda and order the mounting bracket that the d-brackets and bushings mount to and that is all.
Re: GSR rear sway bar...bolts on to EK hatch? (EK-SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-SI »</TD></TR><TR><TD CLASS="quote">if you have the gsr endlinks you can use those or si ones will work and you will also need to go to honda and order the mounting bracket that the d-brackets and bushings mount to and that is all.</TD></TR></TABLE>
explain how the gsr endlinks will work? the si ones are totally different
Re: GSR rear sway bar...bolts on to EK hatch? (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight »</TD></TR><TR><TD CLASS="quote">explain how the gsr endlinks will work? the si ones are totally different</TD></TR></TABLE>
use a nut and bolt
use a nut and bolt
Re: GSR rear sway bar...bolts on to EK hatch? (white eg in tha LBC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white eg in tha LBC »</TD></TR><TR><TD CLASS="quote">
use a nut and bolt</TD></TR></TABLE>
their lengths are entirely different... i would work on eg lca's but from everything i have seen they are like an inch short for ek...
if everyone is saying they work.. i wanna see a pic..
this will save me money since i have gsr endlinks...
DaiJekBok
08-22-2005 06:06 PM
Solscud007
12-09-2004 03:48 PM
SuperCivic
07-22-2004 03:04 PM
x00gsr
06-01-2003 06:15 PM
