GSR rear sway bar for my 2000 Civic Sedan
I just got a rear sway bar from a Integra GSR(14mm) 97 I believe and I want to know what specifically do I need in order for this to work & where to get it from & is it a big deal if I don't get a front sway bar?
All your help is needed. I have a 2000 Civic LX sedan & trying to upgrade my sloppy suspension so I found this sway bar for cheap & need your help.....
Re: GSR rear sway bar for my 2000 Civic Sedan (Dark_Ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark_Ferio »</TD></TR><TR><TD CLASS="quote">Bump....I searched but got unclear results</TD></TR></TABLE>
you did?
I got results looking at posts from this afternoon in this forum. I can't be bothered to find them, but try a little harder....
oh... I researched it a while ago too, and found all the info clearly laid out as well... but I can't for some reason be bothered to search for you for those either...
I know that it is there though.
Good luck.
you did?
Good luck.
Re: GSR rear sway bar for my 2000 Civic Sedan (SuperSlow)
So buy the 99-00 SI end links and then buy what? I've heard from bushings to d-brackets to buying a reinforcement kit for a stock sway bar.......Someone with some clear results who knows what they are talking about pleez help a brotha out!
look up ASR.
Then decide that you don't want to spend the money. Install your gsr bar with si endlinks and new bushings/dlinks. drive around and see if your bottom tears out.
You have not been searching. You probably will not get your answers bumping this.
seriously... just go to search.. set the button to archives... select forum as 92-00 civic/del sol and type "gsr endlinks" or "gsr sway bar"
anything remotely close to that will give u all the info you need..
if u cant find it PM me and ill give u the link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">look up ASR.
You have not been searching. You probably will not get your answers bumping this. </TD></TR></TABLE>
IMO, the ASR subframe reinforcement is an over kill for a stock GSR rear sway.
Call me crazy, but I know that civic and integra suspension are identical, so how would a STOCK gsr sway make stock suspsenion tear out? I've only heard of that happening on cars that are raced competitively with huge sways.
SE7EN3S
14
08-23-2004 01:02 PM
