How do i install front speakers? Im looking at the connection, and it looks like i might have to cut
Do i have to? Cause my aftermarket speakers seem like i have to cut the wiring and re crimp it wtih some connectors so they hook up to the speakers. Is this the case? Or am i missing something here?
Re: How do i install front speakers? Im looking at the connection, and it looks like i might have to
If you bought aftermarket speakers, you can cut and crimp on butt (or maybe spade?) connectors. I suggest going to a stereo shop and getting a connector that plugs into the OEM connector and has two leads that will fit onto the speaker with the proper connectors.
i installed my front speakers, i had to cut and strip wires and then sauderd them together, it doesnt take that long and will save you some money
What do u mean together? Theres 2 wires right? I was thinking of doing like the guy suggested above and getting connectors with the butts at the end so it can fit the speaker connections. i dont get why the fronts had to be this way, my rear speaker stock connections didnt have this problem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matador »</TD></TR><TR><TD CLASS="quote"> Theres 2 wires right? I was thinking of doing like the guy suggested above and getting connectors with the butts at the end so it can fit the speaker connections. </TD></TR></TABLE>
Yes, there is a positive and a negative; I'm not sure what he means either. The reason I suggest the clips, is just that it's easier than soldering to go back to stock, and you can't mix up the pos and neg wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matador »</TD></TR><TR><TD CLASS="quote"> i dont get why the fronts had to be this way, my rear speaker stock connections didnt have this problem...</TD></TR></TABLE>
Really? Both my front and rears have harness connectors, I beleive.
OK one more thing, im looking at the wires, and theres one blue wire with white stripes, and the other one is white with a black line down it. WHich is positive and which is negative?
buy a speaker harness from bestbuy or something. Like $5 keep it stock.
Wazup
Audio / Security / Video
12-31-2003 04:30 PM
