will suspension from ek fit a eg?
Do you guys know if the omni or tein coilovers made for a ek bolt up to a eg hatch. any help would be apprieciated thanks
Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">just change out the rear strut mount bushing and it will fit. use the one for the EK... cheap.</TD></TR></TABLE>
will work if you do that.
Re: will suspension from ek fit a eg? (jdm_eg94)
O.E.M. EG struts have brackets for brake lines.
EK struts do not have those brake line brackets.
If you use EK struts on EG, you have to figure out a different way to mount your brake lines.
or you can grind them down. that's what i did to my gsr rear lca's in order to accomodate some tein flexes that were made for ek's.
1 Post
grinding will work as well...i like grinding... but with an EG, the bushings are old and should get swapped anyways. if they are high spring rate coilovers, new bushings are for sure a good idea. i will post a pic later of what my 8k omnis did to a rubber bushing. its nice.
i'm planning on doing this as well. i have Tein SS coilovers from an EK that are going on my EG and i'm planning on gettin either OMNI or NAR-SPEC Lower Control Arms. How do i get the bushings out so that i can put the EK ones in? Hydrolic Press i'm guessing??
1 Post
yes a press. the bushings come out easy if you have the right tools. if you are going to replace the lower arms, just take them to a shop and have them do it real quick. it takes a few minutes.
93bluehb
01-16-2007 06:33 PM
TORQUE MONSTER
10
06-21-2006 07:52 AM
i20444406
03-13-2005 09:48 PM
