Manual Trans fluid, what to buy and where?
1.5L sohc non vtec, Manual trans about 136,000 miles
Doing new axles and new trans fluid,
I bough 3 quarts of Vavoline 80-90 Gear oil, but then hesitated after I bought it.
So now im posting here for the Experts to tell me What fuild and where should I buy it, since I KNOW you all are going to tell me NOT to use it!
Lets start off, I got Autozone, Advanced and Napa Near me, who sells decent **** ?
Advanced only had Lucas and Vavoline and some cheap ****........
1 Post
DO NOT USE THAT OIL. your honda uses 5w30 SL grade engine oil. I only use HONDA MANUAL TRANSMISSION FLUID. But in a pickle, you can use any quality 5w30 engine oil. Mobil standard 5w30 is fine, buy it from Walmart for 1.82 a quart. You will need about 3 quarts to fill the transmission.
Re: (littleredcivic)
Your saying I can use MOTOR oil? So I can use the same oil I use in my motor in my trans? Which is Vavoline 10w-30 non synthetic
Re: (blkhatch92)
WOW, thats a NEW one to me, Motor oil in a trans? I was always told gear lube is btter for the differential..........
ok, off to walmart I go, So how bout some 10w-30 or 5w-30 Mobil 1 Motor oil or Vavoline ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">You will need about 3 quarts to fill the transmission.</TD></TR></TABLE>
I believe it's 1.8qts unless he's rebuilding the tranny, then it's somewhat more. Use either Honda MTF or GM Syncromesh FM.
Well, Last time I used Penzoil, I think it may have F%^ked up my trans, It was also told that it was great for my ford, even though it says for GM and Chrystler use.
BTW, at VERY high rpms, I grind 3rd gear
Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">Honda Genuine MTF </TD></TR></TABLE>
go to the dealer and theyll help you out
Re: (96dxpower)
ok ok, i may have to do that, just figured/assumed the dealer would charge me out the *** for th4e fluid, so Id rather buy some **** around here that is aight to use, like mobil one or penzoil.........
1 Post
the honda manual transmission fluid is an engine oil with an additive from what my friend at honda america told me. it is under 4 bux a quart at the dealer. if you are going to use something other than the original manual transmission fluid, buy the regular mobil. it is the closest to the honda factory fill, honda oil is made by mobil. if it was meant to be synthetic, the factory would have filled it with synthetic.
Either honda MTF, Synchromesh, or 5w30. i will only use Honda or synchromesh in my honda. the 5w30 is only for a "temporary" thing though. the MTF have extra anti-wear additives to protect your tranny.
Re: (fistandauntilus)
I just put AMSOIL in mine. I noticed a big difference. Seemed like the gears went in smoother and the whole car accelerated faster. It's a Synchromesh as well.
Could just be me getting loopy on fumes from exhaust.. but I swear it was better than the stock MTF.
https://www.amsoil.com/storefront/mtf.aspx
Re: (johnecon2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnecon2001 »</TD></TR><TR><TD CLASS="quote">I just put AMSOIL in mine. I noticed a big difference. Seemed like the gears went in smoother and the whole car accelerated faster. It's a Synchromesh as well.
https://www.amsoil.com/storefront/mtf.aspx</TD></TR></TABLE>
Worth a shot?
Worth a shot?
Re: (johnecon2001)
Aight, Well I appriciate all of youyr comments, opinions,
I went to advanced. returned the Vavoline crap and went to honda and got the basic Honda trans fluid!
thank you! I hope im going to be happy!
O- and it cost me 25.00 after taxes. so a lil more than other stuff, but, if you say its good I got it!
Re: (zx2gotboost)
Well, new axles are in, Honda fluiod in with a tiny bit of Lucas oil additive, got in my car started it up, pushed clutch in and moved shufter first to second to 3rd gears, WOW, what a difference NEW tranny oil makes, shifts better than it did! and thats at Idle.
But another problem..........................
When I pulled the lower control arm balljoint, the cotter pin was broke off in the castle nut (17mm) I loosened the castle nut anyway, now I CANNOT put the castel nut back on all the way!!! thankfully I got it on 2 or 3 threads, but thats all!
So im screwed once again.................
and I know nothing about that balljoint, I wonder if I can just replace the ball joint thing?
