GC W/ Koni Yellows too lowW!
i just installed my GC + koni set up. the front of my car is slammed with the coilovers all the way up. why?!! i can't figure it out.
Re: GC W/ Koni Yellows too lowW! (bolsaman)
the koni yellows should have 3 different height settings, which slot is the ring on the koni's sitting on?
what spring rate and length did you get? with the threaded collars on the very top circlip of the konis, there should be no reason you are so 'slammed' as you describe with either 7" or 8" springs or even the off the shelf springs. Unless you have the collars switched from front to rear.
Also, did you get the koni-specific sized GC collars?
where are the adjusters on the sleeves, maybe you just have them set too low
if I remember correctly, the long ones are in the back, and with them on the middle groove, with may car at 4-5" off the ground, the adjusters are set pretty low.
did you install the sleeves correctly.
did you put the little donut thingy in the sleeve (or do you have the baby sleeves?
Modified by Crazydave at 12:20 PM 12/28/2006
Re: GC W/ Koni Yellows too lowW! (Crazydave)
um, u mean the bumpstops? i cut those in half and used the top half like the instructions said. i have the ground controls made for koni's. i'm sure i got the correct spring and sleeve in the front and back. the front koni shocks have 2 levels, i put it on the top one and the rear koni shocks has 3 levels, i put it in the middle.
the middle and top koni rings should be fine,
the bump stops should be fine...
how far off the ground are the side rails of your car (from the ground to the jack points)
|__|
| ^----------little metal donut ring
^------Sleeve
you should have plenty of ajdustment to lower and raise your car?
What length springs do you have?
|__|
^------Sleeve
Lambo123
Suspension & Brakes
11
07-21-2012 10:32 PM
