Another o2 sensor problem
I have a Ej8 with a b16a2, and i am running a odb1 ecu im using the jummper harness to make it odb2 to odb1. Now the question i have is i Have a high flow cat, and i still run a O2 sensor in it, and its bad it threw a check engine light befor the engine swap, Now sence im odb1 does it not use that o2 sensor or does it not use the o2 sensor that was in the old D series header??? Any help would be great
Re: Another o2 sensor problem (namewasdallas)
I have the same issue but the resolution i am going for is getting a chip to eliminate the code bro try that if nothing else works.......Since to my knowledge obd1 b16s like myself only have one o2 sensor or maybe i am wrong....
wootcivic
11-29-2004 10:01 AM
