Substance in intake
Substance in intake
Took off my intake a found green supstance in my intake, looks like its comming from my head through the tube connecting the head & intake.
Anyone know wtf this crap is? & or what's causing it?
Thanks for any help.
Re: Substance in intake (eg6BT)
Ive never seen anything like that on anyone's car before.
What exactly causes it, im trying to figure out why my car's blowing out
snot.
snot.
GDD's Dr. Phil?
Re: Substance in intake (Corey_sl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corey_sl »</TD></TR><TR><TD CLASS="quote">Took off my intake a found green supstance in my intake, looks like its comming from my head through the tube connecting the head & intake.
Thanks for any help. </TD></TR></TABLE>
Oil is not green my friends, that is coolant. You took off you intake pipe or intake manifold? some kind of headgasket problem would be my best guess, but i dont fully understand where you found this stuff, got a pic?
Re: Substance in intake (oneludesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol »</TD></TR><TR><TD CLASS="quote">
Found it in the tube circled, and on the inside of the intake arm where the tube connects.
Its kind of blurry, lmk if it helps though. I can take a better pic tomorrow when its light out if need be.
Re: (spray_bombed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spray_bombed »</TD></TR><TR><TD CLASS="quote">yeah thats the breather hose..but are you sure its not just old *** oil sludge?</TD></TR></TABLE>
It could be but ive cleaned it out a couple times & it came back again.
Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">You have the vacuum line from the valve cover connected to your intake, right? Not something else?
Coolant in your valve cover spells doom.</TD></TR></TABLE>
Its the tube that came with the intake when I purchased it.
Why is this bad?
Why is this bad?
Re: (Corey_sl)
For the love of god change your oil and coolant and check for mixing! You may be doing a head gasket in the near future.
Also a pic of the substance might help us say for sure.
Re: (ho bag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ho bag »</TD></TR><TR><TD CLASS="quote">For the love of god change your oil and coolant and check for mixing! You may be doing a head gasket in the near future.
Also a pic of the substance might help us say for sure.</TD></TR></TABLE>
I changed my oil a couple days ago, & filled up my coolant the day after.
Looked for sh*t's and giggles yesterday because I hadnt looked to see if it came back in a couple months and it was there.
But this is what ill do, ill take pictures of what it looks like post them up and clean it out and see if it comes back.
if you are referring to a very light green almost yellow color, and its thick but moveable, i have seen this before on other c ars, a good example is many jeep liberties, they get a huge glob of this stuff under the oil cap. i have found out that it is when oil and condensation of water mix on engines that are not driven long at all. basically lack of full warm ups, and full temp long cruising operation can cause this, it is of no harm, and when you pour oil onto it it flows back into the motor and gets eaten by the pump no problem. [when i said think i dont mean it can clog, its just a goo like gell state.] if this is it, i just reccomend take a long *** drive and get the motor nice and warm for a long time, and do this every once in a while
Re: Substance in intake (fastrc2)
I haven't looked on mine yet, but do these cars have an EGR plate inbetween the TB and the intake that coolant runs through? If thats the case, it could probably be an EGR spacer gasket.
