Anyone now how to instal a EG OEM stock Strut Tower Bar on a 94 Civic Ex Coupe ?
I noticed that some of the Civic's 92-95 where sold with OEM Strut Tower Bars like the stock one that the 99 Civic Si has. Anyways, I seen these on EG6 and EG9 and would like to instal one on my 94 Civic Coupe EJ1. Any ideas ? Need Help??
true, seems easy, but I think it needs to be linked with other conponents. Think honda would have the specs on what to use in order to make this work ?? Anyone?? Not into it for looks!!
HT White Ops
Re: (dj theoretic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj theoretic »</TD></TR><TR><TD CLASS="quote">true, seems easy, but is there a point to this Strut Bar. I think it needs to be linked with other conponents. Think honda would have the specs on what to use in order to make this work ?? Anyone?? Not into it for looks!!</TD></TR></TABLE>
I have one on my car. That's how I installed it. There are no specs because the cars that come with them have the bolts pre-welded to the chassis. On the cars without them, there are dimples on the shock tower to show you where to drill. There are no linked components, it doesn't attach to anything else. If you understood how it worked, then you wouldn't be asking these questions.
Just use SAE Grade 8 / Metric Grade 10.9 bolts if your worried about structural strength.
Re: Anyone now how to instal a EG OEM stock Strut Tower Bar on a 94 Civic Ex Coupe ? (BlueIntegraBoy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">My EH2 had rubber grommets covering the 4 holes. Maybe the EJ1 is the same. If it is, you won't need to drill, just feed bolts through and bolt the bar in.</TD></TR></TABLE>
Yes I believe mine had the rubber grommets covering mine too.
most civics i've seen had lil rubber gromets covering the holes. others need to b drilled but have dimples to show where they should be. just drill(if u need to) then use some nuts n bolts. simple as that man and nothin else
do u remember what size bolts u used, cuz i just got a gsr bar but it didnt come with the bolts.
deschlong
12
07-05-2013 09:47 PM
graveltravel
10-11-2005 06:04 PM
AlphaQup
Suspension & Brakes
06-24-2005 07:10 AM
