4dr eg door problem
4dr eg door problem
today i opened my rear driver side door, put somethings in and shut it. Then i went to open it again and it wont open. The lock is up meaning its open(manual) and it wont open from the inside handle either, what could be the problem??? Thanks in advance!
Re: 4dr eg door problem (japspecb7)
it sounds like the linkage between the handles came off... best bet i would say crawl in from the other side and just remove the handle from the inside and see if you can get the door open,the linkage should be right there when you get handle the loose should be able to pull on it and open the door; unless its loose from the outside handle.if it is you might have to get something(wire clothes hanger maybe) and try to pull the lock loose from the inside..just my 0.02
4dr.power!
4dr.power!
Re: 4dr eg door problem (project4dr-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project4dr-eg »</TD></TR><TR><TD CLASS="quote">it sounds like the linkage between the handles came off... best bet i would say crawl in from the other side and just remove the handle from the inside and see if you can get the door open,the linkage should be right there when you get handle the loose should be able to pull on it and open the door; unless its loose from the outside handle.if it is you might have to get something(wire clothes hanger maybe) and try to pull the lock loose from the inside..just my 0.02
4dr.power!</TD></TR></TABLE>
thats sounds like a plan ima go try right now
well i took the door handle off and the metal rod that attatches to it wasnt there so thats why it wont open from the inside.
but i still cant figure out the outside it just wont open from the outside, everything is attatched to it but it just wont open. Also when i pull the outside handle it wont go back in by itself i have to push it back in place. so idk.
Re: (japspecb7)
is there any tenstion(if i spekked that right) when you pull the outside handle?.if not it just might have came off alltogether. dont know how tha hell you did this lol .really dont know what i could tell ya to do...
