need help with tranny
my fifth keeps poping out, and people told me that the reason is low fluid. and if thats is true. I can't find the fill hole and the drain hole. and last question how do i know how much to put in. please help a bro out.
Resident Gearhead
Re: need help with tranny (thedao)
Unthread this bolt to fill tranny, it has a crush washer behind it that should be replaced also. Fill it on level ground until oil spills out of the hole - fool proof.
The drain bolt is lower on the tranny and has a square hole that fits a 3/8" rachet.
if its pooping out of gear, check thoroughly all engine/ trans mounts, then check the shift linkages for proper sliding/pivoting action, then check the adjustment of the shift linkage. these all affect the gears ability to stay in gear.
Resident Gearhead
Re: need help with tranny (fastrc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrc2 »</TD></TR><TR><TD CLASS="quote">if its pooping out of gear, check thoroughly all engine/ trans mounts, then check the shift linkages for proper sliding/pivoting action, then check the adjustment of the shift linkage. these all affect the gears ability to stay in gear.</TD></TR></TABLE>
He is right, forgot to say that tranny oil is probably not the problem.
