Window Problem**** Any Suggestions?
Coupe Window Problem**** Any Suggestions?
Hey guys...
So here is my problem... My GF has a 99 civic ex which has a problem with the driver side window. Every now and then the driver door window decides to pop out of the guides and i can't figure out why it's doing it. It just does it randomly from time to time decides to pop out. All the screw and everything is tighten and in place, I don't see any problem...
Maybe someone else has this problem that came up with a solution
Re: Coupe Window Problem**** Any Suggestions? (Shushiplease)
Well the window keeps coming off of track. What u need 2 do is get some type of lube on those tracks. So the window will slide up and down smooth.. And I'm talking about the tracks behind your door panel.
Re: Coupe Window Problem**** Any Suggestions? (EK_kidd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_kidd »</TD></TR><TR><TD CLASS="quote">Well the window keeps coming off of track. What u need 2 do is get some type of lube on those tracks. So the window will slide up and down smooth.. And I'm talking about the tracks behind your door panel.</TD></TR></TABLE>
That's what I did, I bought the silicon lube and I lube it every once every month and so far so good.
dang, never thought of that... I will try it out later today... Much <3 to my honda-tech bros!!
So the grease didn't work... I actually think it made it worse! =X Anyone have any idea how to fix this problem?
Did you buy actual silicon lube? If you didnt, go get it.
Be sure that when you spray them down, you spray the hell out of them to get em nice and lubricated lol. Make sure you get actually inside the rubber stripping, and that you get the entire thing.
