Searched - Wiring Question
so i searched this, and couldnt really answer my question with the results...
i have a 94 CX hatch that has a mini me swap in it with a Y7 block and Y8 head. It has been converted to OBD1. VTEC has been wired from the VTEC solenoid to the ECU.
my question is, on the passenger side, the plug over there, could i theoretically wire my VTEC there and my knock sensor? and on the ECU plugs, do i just need to re-pin the plugs or add wires?
my last swap was easier because the VTEC and the knock sensor had already been wired...
thanks in advance
thanks in advance
Yup, you can wire in the vtec and knock sensor wires to their stock locations on that shock tower mount plug, as long as you wire it from there to the ecu as well. You could use this as a diagram, if you're using the OBD1 engine harness:
http://www.ff-squad.com/tech/w...g.jpg
And yes, you'll have to re-pin the plugs to add wires.
ok quick question, i would need to add the wire on the shock tower mount plug correct? from the ECU to that plug and then one on the engine side as well correct? just making sure... dont want those pesky CEL
