NEED HELP! EK is dead
my 00 hatch with y7/y8 mini-me was working fine. Now it wont start. No cel's. The fuel pump wont come on, no spark, injectors are dead. I checked all fuses, replaced the main relay tried 3 different computers . I was able to get it running once by jumping the fuel pump. Which the fuel pump will work when I do this. But the car now doesnt run.
Re: NEED HELP! EK is dead
Everything checked good. Im a bit un sure about the step that says to check for 5 volts. Both reading I got 4.97 which is close enough I guess.
I suspect that some tests were not done or interpreted correctly, so you need to give details about how you are doing the tests and what readings you are getting.
First verify that the engine won't start. Then repeat all tests. Post the readings at each step and, where there are branch points, indicate which branch was taken.
