Ac with a b series
Re: Ac with a b series
It sounds like the former from my interpretation, but I could be wrong... We're both right though, if he's using D, you're right, if he's using B, I'm right.
i've recently done this. here's the rundown
-if you want to use your stock a/c lines and stock a/c compressor, just get a 97-01 CRV a/c bracket ('P7J' if i remember correctly) or B-series vtec del sol and it will hook up the d-series a/c compressor and it will bolt on the b-series block. Works wonders and probably the easiest way to do this
- get a '99-'00 EM1 a/c compressor, any b-series a/c bracket (besides the crv or B-series del sol) and EM1 a/c lines. It'll work with your set up. I know this cuz i've got this setup in my LSVTEC
good luck, mate
good luck, mate
good luck, mate
good luck, mate
Not thread jacking, but i have a b16a with the b16a ac bracket on it. can i use all D series also?
Crazy Honda Guy
The only way to use the B compressor is to change the lines, which i don't think is worth the trouble
But I will only have to change the short line from the top of the condenser to the compressor and the short low pressure line from the compressor right?
From Deetz's pic, you'd need to change 4 and 5. I have personally done this myself. That is what you need to replace to use the B series compressor.
HAMOTORSPORTS sells various AC brackets for B series with D compressors but they're pricey
http://www.hamotorsports.com/air-conditioning.html
