limp mode or no????
limp mode or no????
my 94 civic wont rev past 3100 rpms acts like its hitting rev limit, throwing a cel code 4 but i replaced the dizzy and even tried different ecu and checked all wiring still nothing. today i was cleaning the intake manifold with tb cleaner with the car on and when i spray it in and push the throttle it revs to just under 6k....so is it limp mode or maybe low fuel pressure or something like that? tell me your input on what u think? thanks
Re: limp mode or no????
i did i check all wiring and grounds tried different dizzys even took the car to a shop and they said replace the dizzy but i already had. when the car is warm it idles at 500 rpm barley stays on....
Did you check the wires with a digital multimeter? If not, that's what needs to be done. You can't find most wire problems by visual inspection. Put all of your energy into fixing code 4.
even tried different ecu's but same code. when car is on the 2nd click before it starts no code only when i start the car does the cel come on. turn off the car and back to 2nd click and no code everytime
Were your tests on the distributor sensor itself inside the distributor? Because that's where you should measure 700 Ohms of resistance. I am saying that you need to test the two CKP wires that run between the ECU and distributor plug. For each wire, you need to run a continuity test to look for an open and a continuity to body ground test to look for a short.
STREETWERKZ
06-23-2004 01:17 PM
