delsol b swap
delsol b swap
ok got a 93 sol s puttin in a 00 gsr motor an trans runnin a p28 is the wiring the same as an eg imma wire the vtec driect to ecu from sensors alson gonna wire in the obd2 dizzy in and injectors
Re: delsol b swap
If all ur componets for the motor are obdII (like the injectors, dizzy, and alt) u should opt for a obdII integra/gsr engine wiring harness, everything will be plug and play. Both sides of the integra harness will plug directly into ur delly on the shock towers and obviously all sensors will plug right in. There is no need to wire anything besides vtec. Ul also need a integra t bracket and integra shift linkage and axles
bmoney
08-13-2006 01:36 PM
DRKSol
07-17-2006 11:48 AM
