1994 civic speedometer issue.
so my speedometer no longer works.
i just put the engine back in the car after a rebuild,
and now it doesnt work.(worked before the motor was pulled)
i had a gsr swap before aswell.
ive tried a new vss,
a new cluster,
running a signal wire to the ecu/vss/cluster,
ive cleaned the pins connecting to the vss,
ive checked all of my fuses,
and still nothing.
i did remove the cruise control module from under
the driver side of the dash if that has anything to do with it,
but i cant find it to throw it back in for troubleshooting.
any help is appreciated!
thanks.
a new cluster,
and still nothing.
thanks.
Re: 1994 civic speedometer issue.
yeah cel works fine.
when you put the car in acc. the
cel cuts on and off after the fuel system primes,
and never comes back on.
well i ran a new wire from pin b2(behind the cluster)
to the yellow/white on the vss,
and still nothing.
and still nothing.
okay but i installed the stock cluster in and still didnt work.
(ive been running a jdm eg8 cluster for the longest time
and had no problems)
Well everything is good behind the cluster.
Im going to test the vss later on today
and see if it works.
You've already replaced the VSS three times. What are the chances that all are bad? In addition, a bad VSS would typically throw code 17. Be a detective and don't ignore obvious clues. If the VSS and speedo/cluster are good, then logic dictates that there is a bad wire or connector.
