Trans Hitting frame
Trans Hitting frame
I have innovative mounts and i just dropped an B18B into my 95 EG Hatch. the Transmission is on the frame and im not sure why. all the mounts r in correctly. has anyone ever run into this problem before.
P.S. How Much manual Trans fluid do i have to put into a Bseries trans? i have to go to the dealer for fluid so i want to know before hand.
Re: Trans Hitting frame
ur probably the only person who has this problem... i have a b20 with innovative mounts no problem with fitment the mounts have to be wrong or something that doesnt make sense at all... post pic i would like to see...
fill the tranny up untill the fluid seeps out the drain hole
Seagull Management
Was the car originally an automatic? Did you get an auto to manual upper transmission mount, or did you cut the automatic pocket mount off the passenger's side frame rail and weld on the manual version?
^^^^ listen to this guy... my friend accord had the problem u have because it was a automatic... he had to order the mount for his H22
ok guys thanks for the help guys. i called innovative and i ordered the right mount. i had the regular one. since i did the conversion i need that m/t to a/t mount, which i just ordered. thats a fu***** load off of my mind. i thought i was going to have to cut the frame out some. lol. HT Does it again!! W00T W00T
the4g4d
01-31-2007 10:20 AM
YEE*MagicEK20kombobomber
08-03-2005 10:08 AM
