Something is wrong with my IDLE Help!! Help!!
I have a 92 si hatch an as soon as i turn the car on its jumps up tp 3,000 RPM's
I Don't know what wrong. The engine isn't not trowing any codes,when i ask people what could it be they say it is the sensor behind my intake manifold. Are they wrong? what could it be?
Thats the sensor
Better shot
Thats the sensor
Better shot
Re: Something is wrong with my IDLE Help!! Help!! (abraunworth)
Is your throttle cable sticking?
Its Weird
Re: Something is wrong with my IDLE Help!! Help!! (JDMRob)
It may be your IAC (intake air conroller) not working right letting too much air past the throttle plate causing high idle. cant say for sure though.
Re: Something is wrong with my IDLE Help!! Help!! (ptran13)
are they saying it's the TPS sensor? I would think distributor, mainly the ignitor or coil pack.
Re: Something is wrong with my IDLE Help!! Help!! (94hondaLS)
Guest
Posts: n/a
Mine did the same thing and it was the intake manifold gasket had a hole in it. Take some carb cleaner and spray around were the intake manifold meets the head and if it revs up then you will know....
Guest
Posts: n/a
Take the IAC off and tighten the plastic screw back in. That sound fix it. Also check the TPS senors. Make sure the voltage is at .4 for idle.
PM me if needed. I'm a litte drunk
Re: Something is wrong with my IDLE Help!! Help!! (I can't believe this ****)
also just try cleaning the IACV. take it off and shoot some carb cleaner in there. I've even used simple green before, let it soak, rinsed it out really well and dryed it out with a hairdryer, worked like a charm and cost next to nothing
Re: Something is wrong with my IDLE Help!! Help!! (Extent)
Where the hell is the thing u guys are calling the IAVC located?
[Modified by JDMRob, 4:02 PM 1/23/2003]
Solbros Owns Me
Solbros Owns Me
Re: Something is wrong with my IDLE Help!! Help!! (sil)
actually, before you pull off the iac...get the car to operating temp, and pull the plug off of it. If the idle goes down, then that's your problem. If not, then look elsewhere. This will be the easiest way to tell you if that's it.
Re: Something is wrong with my IDLE Help!! Help!! (eg6ken22)
Thanks for all the info i will check it out tomorrow an see if i can fix it my self...... Any more suggestions Greatly Appreicated
Re: Something is wrong with my IDLE Help!! Help!! (Emerica)
There are 3 coolant lines and 2 12mm bolts.
