Couple of suspension and brake questions...
Couple of suspension and brake questions...EJ1 Coupe - DC2 Teg compatibility
I'm just about ready to order up my suspension and i have decided on a set of kyb agx's with some h&r sport springs. Now the thing is i have a 95 civic ex and i am gonna probably swap my rear brakes from a dc2 teg later on, but i should be fine doing this because the agx's are the same for a 95 ex coupe and a 94-00 teg. Also does anyone recommend buyin the integra springs from h&r because they'd be the same but higher springs rates? just a though. But also if anyone has links to a good brake swap install page let me know, thanks
[Modified by GasHuffer, 10:21 PM 1/22/2003]
Re: Couple of suspension and brake questions...EJ1 Coupe - DC2 Teg compatibility (GasHuffer)
keep in mind that if you buy the springs from the teg that your car may not be lowered as much due to the higher spring rate... There was a guy a while back who put SI springs on his hatch and it actually "lifted" the hatch.
I used the howto on http://www.hazone.com/hdiscswap.htm to do a rear disc conversion on my civ.
[Modified by kommon_sense, 12:17 AM 1/23/2003]
Re: Couple of suspension and brake questions...EJ1 Coupe - DC2 Teg compatibility (kommon_sense)
[Modified by euclid, 1:25 AM 1/23/2003]
hxtasy
03-10-2006 08:33 PM
