Has anyone done a rear disc conv on a slo?
Thinking of doing a rear disc conv from a teg or Si hatch for aesthetic and performance reasons (readying for GSR swap). I've been thinking though; will it upset the front/rear brake balance to an unsafe degree? The last thing I want is high speed instability, and I'm not a big fan of drifting at the moment.
And if it does, would beefing up my front brakes be an idea?
Guess I should've gotten a damn Sol Si in the first place. Shizzmit.
Re: Has anyone done a rear disc conv on a slo? (Hythrax)
IIRC, the del sol vtec came w/rears. So this should basically be a bolt-on swap. However you may need to swap some parts form a del-sol vtec to make it all play together nicely (ie prop valve, e-brake cables, brake booster, etc.)
Actually looks like a lot of the del sol models came with rears (some si and vtec). You can call up a honda dealer and double check part #s to see if you need the brake booster or mc from one of those models.
[Modified by kommon_sense, 12:00 PM 1/22/2003]
gmcuajo1
06-22-2014 07:23 AM
Eg2707
12-21-2006 12:45 PM
