Radiator hoses for a B-series
What kinda hoses did you use for your swap with a stock civic radiator? Will GSR hoses work, and bend right? We used one of the stock hoses but it has a VERY VERY slight bend in it so we could get it to fit... will the GSR hoses fit the motor like a glove and reach the radiator? I know I'll still have to double clamp em and all.
Thanks in advance.
Thanks in advance.
New User
Re: Radiator hoses for a B-series (Plan B)
gsr hoses if you're using a gsr head, si hoses if using a b16/type r head.
Mine fit/look perfect.
Re: Radiator hoses for a B-series (fOmaNPu)
The Si hoses won't work, they don't fit. We've tried this once already.
I can't rightly goto the store and ask for JDM radiator hoses...
This is why I'm asking if anyone has used the Integra hoses or know if they'll work alright...
Go to a different store, they probably gave you EX hoses or something. I'm telling you 99-00 si hoses are the trick.
If it's that big a problem, buy an integra lower hose and just get a universal flex hose for the top.
New User
Re: Radiator hoses for a B-series (nsxmatt)
You should get some of these bad boys. Only $310 a set! I think I might get OEM honda first, thanks plan b and the rest of you guys for the info!
Re: Radiator hoses for a B-series (Blake K.)
Order the hoses from the engine you have not the car or radiator. The teg radiator puts the inlet and outlet in the same location as a civic one.
Re: Radiator hoses for a B-series (w00t!)
Re: Radiator hoses for a B-series (Blue-Civic-Hybrid)
I have the upper radiator hose with clamps if anyone needs it. The clamps are used but those hose is brand new from Honda.
Wdpfreak145
04-23-2012 10:54 AM
tempsohc
08-28-2006 08:53 AM
spoonek4
01-12-2006 11:41 PM
