What do I have to do my B16A in order to make it equal to a B16B?
What do I have to do my B16A in order to make it equal to a B16B? OEM wise Im talking, I know the IM and header flow better on the B16B, also CTR Cams, but what is my engine missing from the B16B?
Re: What do I have to do my B16A in order to make it equal to a B16B? (E. Honda)
don't forget CTR pistons. Then there's the valvesprings and retainers so you can rev higher. The tranny I think is the same except for the lsd and the CTR has dual synchros in the higher gears. lsd. I love mine. I highly recommend one. And while you're in there if you want super short gearing (which the b16a could use) you could put a JDM 4.785 final drive in. there's probably some more stuff but I'm not sure.
s
s
The B16B is a de-stroked B18c block. So to answer your question you can't really truly turn a b16a into a b16b.
Re: What do I have to do my B16A in order to make it equal to a B16B? (Doctor CorteZ)
um , get a 1.8 block and destroke it
Whoa, there is no need for the hammer head, its a simple question, not everyone is a certified Honda mechanic as I'm sure you are.
you didnt know , I did.
Former Moderator
B16B = most over rated Honda motor.
GS-R motor would beat a B16B.
Re: What do I have to do my B16A in order to make it equal to a B16B? (B18C5-EH2)
best way to make a B16 fast is take it out and put a 1.8 in....
I'm a dick , live with it.
please don't hurt me
totally agree.
totally agree.
Re: What do I have to do my B16A in order to make it equal to a B16B? (Nextekhatch)
Nah, i think b18c (JDM GSR) could beat it, not a regular b18c1.
please tell me what the difference is in the US/JDM engine.
does the torque of the 1.8 really make that big a difference?
and the 2.0 liter makes even more of a difference.
1.6 Honda motor is a waste of time to build up.
um , yeah
um , yeah
Re: What do I have to do my B16A in order to make it equal to a B16B? (YumVTEC)
higher compression in the JDM b18c (SirG) vs USDM b18c1. 180hp vs 170hp.
But with the proper bolt ons
CAI
Skunk2 IM
Cat back Exhaust
4-1 header
2001 ITR Cams
Do you think I would be about 185 crank HP?
CAI
Skunk2 IM
Cat back Exhaust
4-1 header
2001 ITR Cams
I know the answer , I was asking him.
CAI
Skunk2 IM
Cat back Exhaust
4-1 header
2001 ITR Cams
Skunk2 IM
Cat back Exhaust
4-1 header
2001 ITR Cams
who gives a rats *** about that ?
take B16 and make it a paperweight , buy LS bottom end , throw VTEC head on and roll.
why is this such a tough concept ?
No way would you be at 185. It takes a lot more than that. What B16A do you have? i assume it's USDM which has lower compression. You need to put some higher compression pistons.
I've got all that and higher compression and I'm almost positive that I won't be at 185.
s
s
CAI
Skunk2 IM
Cat back Exhaust
4-1 header
2001 ITR Cams
crank HP ?
Skunk2 IM
Cat back Exhaust
4-1 header
2001 ITR Cams
crank HP ?
Former Moderator
Re: What do I have to do my B16A in order to make it equal to a B16B? (stevel)
Well the 10.6:1 CR JDM 180hp GS-R motor would certainly romp a B16B.
The B16B is a killer motor from an engineering standpoint, but that more torquey and only 5 less crank hp'd B18C motor would still be quicker and it costs much less too.
USDM GS-R motor? I still think I'd take that over a B16b too when considering price.
Former Moderator
I do however disagree with Doctor Cortez.
I'd choose a GS-r bottom end over an LS any day.
LS bottoms ends have a worse r/s ratio, and if I'm building a motor that revs to and over 8500rpm I won't do it with a bottom end that was never meant for above 7500rpm.
Others will disagree, but that's just my opinion based on how I'd use the motor.
Former Moderator
Re: What do I have to do my B16A in order to make it equal to a B16B? (HybridHackBatch)
its all about the LS motor
If going all-motor though, ditch the LS tranny.
