Water pump replacement?
I remember that the water pump is a part that can wear out. A lot of friends have ended up replacing theirs... I have a 99EX; how many miles should I go before I replace it, or should I replace it at all?
Also.. do I need any special tools to replace a timing belt? I have about 10k miles left on it, but I look into maintenance early.
Solbros Owns Me
Re: Water pump replacement? (parasonic)
do the water pump when you do the t-belt.
No special tools for the belt, just a strong enough breaker to get the crank pulley bolt off
Re: Water pump replacement? (Emerika)
Does this balancer belt ever need replacing?
Also... where do you recommend I get a new timing belt and water pump?
Thanks!
Thanks!
Re: Water pump replacement? (zigs)
do you guys also recommend lettin the dealer install it ? and how much did it cost for the timing belt nad water pump to be replaced?
spluvs2install
08-26-2006 07:40 PM
unhappy_idle
05-22-2006 10:16 AM
JDM DC2
08-29-2002 11:39 PM
