Heater doesn't work
Heater doesn't work
I have the 96-98 climate controls. When I push the control from cold over to the heat, It still blow out Cold air. It work before, but now it just suddenly stop working. My heater doesn't turn on. Any clues to the problem?
Re: Heater doesn't work (CereaLand)
can you feel the control switch open and close when you move it? the actual lever that allows cold or hot air is under the dash by steering wheel, or was on my car. sometimes the lever came off the tracks.
Re: Heater doesn't work (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">my freind had the same problem and it was the cables domeing off the tracks. check that first. good luck</TD></TR></TABLE>
If the cables came off of the track, is it easy to fix? Just stick the cables back on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CereaLand »</TD></TR><TR><TD CLASS="quote">
If the cables came off of the track, is it easy to fix? Just stick the cables back on?</TD></TR></TABLE>
Yep, you have it.
Yep, you have it.
dohc-father
01-21-2009 08:47 AM
