Help...... Shifting problem
Hey guys i was wondering if you guys can help me. I have a Gsr in a Eg and not until last night that i was having trouble shifting. When i take it to like over 3k its very hard to shift. It feels like it stuck and then when i let the rpm die down then i can get into the next gear. I know its not my tranny because it was working fine with no grind. Do you think that its the shift linkage. Please help thanks
Re: Help...... Shifting problem (eternal780)
that was the same thing it was doing to me when my clutch went out....also your tranny fluid might be low....good luck and let us know what happens
New User
Re: (eternal780)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eternal780 »</TD></TR><TR><TD CLASS="quote">ima try that today im getting a new clutch thank ill let you know what happens </TD></TR></TABLE>
Whoa, wait. Before someone makes money off you, I would recommend changing the tranny fluid and or bleeding the clutch. Your slave/master clutch cylinders might be going too. You might spend way too much on something you don't need.
hey guys i opened up the clutch and one of the springs came off of the clutch. So im puting on the clutch later today and see how it goes thanks ill keep you posted
Re: (eternal780)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eternal780 »</TD></TR><TR><TD CLASS="quote">hey guys i opened up the clutch and one of the springs came off of the clutch. So im puting on the clutch later today and see how it goes thanks ill keep you posted </TD></TR></TABLE>
yes that would indicate a broken clutch
Hey guys it was the clutch i had it fix and its driving smooth now. Just need to break it in and it will be fine. Thanks for all the imput
supereg2
03-21-2008 09:51 AM
killyourscene
Honda Civic (2006 - 2015)
39
01-27-2008 09:21 PM
