Will 99-00 si coupe stock b-piping fit 96-00 hatch?
Re: Will 99-00 si coupe stock b-piping fit 96-00 hatch? (sykol)
IF it has B series motor and header and cat the B pipe will fit no prob example a Hatch with a B16 and cat would be the same as the 99-00si or any other B series motor with the bottom portion of the header of a 99si so that placement would be in correct spot.
jus f0 dekarayshunZ
Re: Will 99-00 si coupe stock b-piping fit 96-00 hatch? (underrated99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underrated99si »</TD></TR><TR><TD CLASS="quote">IF it has B series motor and header and cat the B pipe will fit no prob example a Hatch with a B16 and cat would be the same as the 99-00si or any other B series motor with the bottom portion of the header of a 99si so that placement would be in correct spot.</TD></TR></TABLE>i was pretty sure that the b-pipes were interchangeable
Re: Will 99-00 si coupe stock b-piping fit 96-00 hatch? (CiRcUiTsi)
They are but on a HB like a DX with a stock motor the B pipe is longer cause the cat is in the header itself so the b pipe is about a 5 inches longer. It will work IM just saying for plug and play
jus f0 dekarayshunZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underrated99si »</TD></TR><TR><TD CLASS="quote">They are but on a HB like a DX with a stock motor the B pipe is longer cause the cat is in the header itself so the b pipe is about a 5 inches longer. It will work IM just saying for plug and play </TD></TR></TABLE>ahh i knew it...i was wondering why my buddy didnt have a cat
crazyguy
06-14-2007 07:52 AM
