Check Engine Light on problems....
Old Mar 26, 2004 | 04:17 PM
civic_boi's Avatar
Default Check Engine Light on problems....
i just bought a civic and the check engine light comes on AFTER YOU DRIVE IT FOR A WHILE....i did the check engine code and the code is 43 Fuel Supply System....what does that mean....please let me know what it is if you know...thanks...
Old Mar 26, 2004 | 04:34 PM
upgraded's Avatar
I would do a check of your fuel pressure. Pump might be going bad, or FPR could be going bad or filter could be getting clogged.
Old Mar 26, 2004 | 04:35 PM
upgraded's Avatar
Might sound funny but does it have a gas cap? check and see if its tight.
Old Mar 26, 2004 | 05:45 PM
civic_boi's Avatar
Default Re: (upgraded)
thanks for the tip...i'll try it and see if it helps.....
Old Mar 28, 2004 | 03:06 PM
ramtyper19's Avatar
Default Re: Check Engine Light on problems.... (civic_boi)
Code 43 usually means the O2 Sensor is lazy. So I suggest U change it. Had the code yesterday on mine. New O2 sensor and i'm fine.
O2 Sensor - $168 (Aftermarket::Not Universal)
O2 Sensor - $250 (Dealer)
B16A2
jayrod7
Jan 21, 2010 01:45 PM
civicsaremean
Jul 15, 2007 07:59 PM
Mad Money
Sep 27, 2006 08:22 AM
2camsaam
Feb 17, 2003 05:58 PM
neumonik
Sep 3, 2002 06:42 AM
