DIY/How to: JDM ITR 4x114.3 brakes onto an EK - Honda-Tech - Honda Forum Discussion
Old 03-25-2004, 07:32 PM
Ricey McRicerton's Avatar
Default JDM ITR 4x114.3 brakes onto an EK
Okay guys, I'm sure I left out a few steps, as I did this and took my tranny out both today. I put bleed the brakes after the ends of both just incase you guys plan to do either of these on their own. The same things apply for the GSR or any other disk brakes though.
Tools you'll need:
10, 12, 14, 17, 19mm sockets
Something to turn those sockets (I'd suggest air tools)
Wrenches (same sizes as above, minus the 10)
Screwdriver
Rubber Mallet
Fronts:
This is a comparison of what you're doing:
1. Break the old axle nut loose.
2.Remove the old brake assembly. Take off the tie rod end from the assembly, as well as the lower bolt under the brakes. I suggest you pull the top bolt shown here seperated off of the ITR assembly, as you can't reuse the ITR top part (UCAs, thanks nerdsports, but it has 2 bolts that you'll have to drill holes for if you plan to use them).
You also will have to reuse the Civic's (LCAs, thanks nerdsports) as the ITR ends are offset, whereas the Civic's are flat.
3.Once you have the old brake assemblies dropped down, slide the axle out. Now you're ready to reinstall the new assembly. Unbolt the brake line, and bolt it to the new one.
4. Reinstall the brakes using the ITR/Civic hybrid assembly.
5. Bleed brakes and enjoy your new stuff.
Rears:
Old and Busted
1.Unhook the e-brake cables from the center console in the car.
-get under the car, unhook the exhaust and drop the heat shield
-pull the ebrake through the rubber grommet (the whole grommet came out on mine)
-unbolt the 2 brackets that hold the e-brake cables on.
2.Use a screwdriver and mallet to bang off the clip on the brake line where it's mounted in the wheel well. (Where the hard line meets the soft brake line.
3.Drop down the whole rear brake assembly (should be pretty self explanitory)
4.Unhook the brake line where you unclipped it. It's a 10mm wrench application. Once you have this off, have the new assembly with INTEGRA rear brake lines attached to it. Unhook the old and rehook the new, as quickly as you can, as to keep brake fluid from getting all over the place.
5.Reattach the new assembly.
6.Reattach the e-brake cables
7.Bleed brakes.
New hotness:
Ricey McRicerton is offline
Old 03-25-2004, 07:35 PM
Civiclx's Avatar
Default Re: JDM ITR 4x114.3 brakes onto an EK (Ricey McRicerton)
nice writeup, looking good!
Civiclx is offline
Old 03-25-2004, 08:09 PM
New hotness
Im planning on doing a complete gsr brake swap myself (very soon) because of bent parts and shot bushings. Oh yeah and wimpy brakes.
Did you upgrade the master cylinder and prop. valve? My car has 4 wheel disk brakes allready so im thinking I just need to upgrade my maste cylinder.
func-tion is offline
Old 03-25-2004, 08:11 PM
Default Re: JDM ITR 4x114.3 brakes onto an EK (func-tion)
I want to re-iterate that I am NOT DONE WITH THE FRONTS yet. I have bolted them up, but no reason in leaving them up there if I have to drop them agian tomorrow to put the axles back in (tranny is still apart from the other writeup).
If any of you guys have done this and see anythign I missed feel free to post it or let me know so I can include it.
Old 03-25-2004, 08:16 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
If any of you guys have done this and see anythign I missed feel free to post it or let me know so I can include it. </TD></TR></TABLE>
looking good so far ricey
kind of ironic because i just did my rear disc conversion on my eg hatch today and was planning on putting it up later on. (had to clean up go to work and now i just got home)
as for the quote you missing the pics while removing/installing you're just teasing us with the 4x114
=GAME= is offline
Old 03-25-2004, 08:22 PM
Default Re: JDM ITR 4x114.3 brakes onto an EK (=GAMEOVA=)
I knew it. You guys would find out I'm a big time pic *****.
In all honesty I was just trying to get the old stuff out before dinner so I was busting tail to get it done and forgot about pics. I can take some of the other side if that would be helpful.
Old 03-25-2004, 08:40 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote"> I can take some of the other side if that would be helpful. </TD></TR></TABLE>
sure that would be nice. give me about 30-1hr and ill host up my pictures of my rear disc conversion from today.
=GAME= is offline
Old 03-25-2004, 08:43 PM
slammed_93_hatch's Avatar
nice man welcome to the 4x114.3 mafia.
now you just gota fill up the wheel alil better
http://www.we-todd-did-racing....D.jpg
slammed_93_hatch is offline
Old 03-26-2004, 06:41 AM
Default Re: JDM ITR 4x114.3 brakes onto an EK (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">nice man welcome to the 4x114.3 mafia.
http://www.we-todd-did-racing....D.jpg</TD></TR></TABLE>
DANNNGG!! Gangsta. What rotors are those? I'm going to get these resurfaced for right now, as one doesn't turn "cleanly" as of right now. I'll see how bad it really is once I drive it though.
Old 03-26-2004, 06:45 AM
nerdsports's Avatar
ricey. the top part (that used parentheses to say you didn't know the name to) is called the upper control arm. and the bottom one (where you used this method again) is called the lower control arm... hehe.
nice write up. wish i could get me some 114, i love them itr wheels. slammed_93_hatch's...uhhh...hatch is so sick!
nerdsports is offline
Old 03-26-2004, 07:09 AM
Default Re: JDM ITR 4x114.3 brakes onto an EK (nerdsports)
^^ Fixed. Honestly I wrote that last night and if I had thought about it a couiple seconds I would have known what they were called. I did that and my tranny removal yesterday and am a little beat. Thanks though nerdsports, you've been acknowledged in the post!
Old 03-26-2004, 08:04 AM
DANNNGG!! Gangsta. What rotors are those? I'm going to get these resurfaced for right now, as one doesn't turn "cleanly" as of right now. I'll see how bad it really is once I drive it though. </TD></TR></TABLE>
prelude vtec rotors 92-9?
Old 03-26-2004, 08:13 AM
nahledge 7's Avatar
some good lookin work there ricey
nahledge 7 is offline
Old 03-26-2004, 08:34 AM
Mr Hammond's Avatar
Cool. Just did this swap on a 97 DX the other week. Good stuff.
Mr Hammond is offline
Old 03-26-2004, 09:20 AM
LSVtecEK1's Avatar
Default Re: JDM ITR 4x114.3 brakes onto an EK (Mr Milano)
looks good. i just took off my 4x114 with advans.....needed money. Now im back to gsr suspension all around.
LSVtecEK1 is offline
Old 03-27-2004, 11:53 PM
mrctr's Avatar
can you post pics of the 4x114 on the ek...
mrctr is offline
Old 03-28-2004, 01:51 AM
Kid1320's Avatar
Kid1320 is offline
Old 03-28-2004, 06:35 AM
Default Re: (mrctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrctr &raquo;</TD></TR><TR><TD CLASS="quote">can you post pics of the 4x114 on the ek...</TD></TR></TABLE>
Sure, as soon as I get the car down off of the jackstands. Fixing the ISB has been taking longer than I thought (and I don't want to bolt the hubs back up only to break them down agian to get the axles in.)
Old 03-28-2004, 07:37 AM
. o 69 o .'s Avatar
Default Re: (Ricey McRicerton)
welcome to the 4 x 114.3 club
have fun finding some new rotors
. o 69 o . is offline
Old 03-28-2004, 07:58 AM
souk's Avatar
prelude vtec rotors 92-9?</TD></TR></TABLE>
92-96 Prelude vtec rotors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">welcome to the 4 x 114.3 club
have fun finding some new rotors </TD></TR></TABLE>
Yes welcome to the OVERSIZE HX club and as far as the rotors give these guys a call.
Endless USA
7283 Murdy Circle
Huntington Beach, CA 92647 USA
T: (714) 847-0694 F: (714) 847-0695
Hours of Operation: 10:30am - 6:30pm PST
Tech: [email protected]
Sales: [email protected]
souk is offline
Old 03-28-2004, 12:18 PM
Default Re: (souk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souk &raquo;</TD></TR><TR><TD CLASS="quote">
Endless USA
7283 Murdy Circle
i really have a hard time seeing how these rims look like HX's its kinda like saying the integra JDM front end conversion looks like an accord.
and does endless usa carry the stock sized rotor
Old 03-28-2004, 02:13 PM
Default Re: (souk)
This guy (souk) helped me get my stuff together on here before I bought it.
My rear rotors were warped when I got them, but they are within spec to be resurfaced. I'm going to have them redone for now.
And I have some HX rims sitting beside the ITR rims.
I can see how they look similar
Old 03-28-2004, 02:21 PM
KOALA YUMMIES's Avatar
JDM rust on the lug seats, mine had the same ****.
KOALA YUMMIES is offline
Old 03-28-2004, 02:23 PM
Default Re: (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">JDM rust on the lug seats, mine had the same ****.</TD></TR></TABLE>
I've even got some jdm dirt and rocks in the tires!! They're JDM snow tires too! If anybody wants to buy any of it let me know!
Old 04-02-2004, 05:12 AM
nahledge 7's Avatar
hey ricey, did you upgrade ur brake lines or just the ones that came with the setup? also what axles did you swap in?
oh yeah, how bout mc and booster?
Quick Reply: DIY/How to: JDM ITR 4x114.3 brakes onto an EK
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
