I want to up grade my brakes for my 93 si
I want to up grade my brakes for my 93 si. I've heard grs rotors are larger than mine and was wondering how much trouble it would be to switch to a gsr setup and what all is needed
TSPeed Factory
Re: I want to up grade my brakes for my 93 si (n2civicz)
i believe you will need the GSR knuckle. rotor and caliper are a must. and integra RS master cylinder and brake booster if you want to do it correctly .
Moderator
DO NOT UPGRADE YOUR BRAKES.....
call me....i'll tell you why....phone number is in signature
i can supply you with BRAKE PADS that will stop you better than getting a big brake system
Re: I want to up grade my brakes for my 93 si (chad)
Well my calipers are shot. I need to replace them anyway thats why i considered the swap. If i keep my stock setup should i go honda remanufactured or just aftermarket?
I upgraded my 92 Si setup to a 2000 GSR setup. Install was way to easy to do. Just some bolts and that was it. Just make sure you will have all the correct cables and stuff, and the e-brake cables on a civic (in my case 92 Si) will work with the GSR brakes. You just have to adjust the bolt by the e-brake.
I Have a 92 Si With 98 GSR knuckles (rotors: powerslot) With stillen pads. the car stops like a beast. But when cold makes noises and grinds.
Re: I want to up grade my brakes for my 93 si (ramtyper19)
i have a 93si with powerslot, stock size, slotted rotors and hawk pads, i scca and autoX my car alot, and i can lock up all 4 wheels with this set up. if you dont get an integra master cylinder, your car will actuallt stop slower cause you cant move the fluid powerfully enough
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">DO NOT UPGRADE YOUR BRAKES.....
i can supply you with BRAKE PADS that will stop you better than getting a big brake system</TD></TR></TABLE>
I agree
If you need better pads than axxis ultimates or cobalt gt sports then get a porsche
cobaltfriction.com
I agree
cobaltfriction.com
Re: I want to up grade my brakes for my 93 si (BauleyCivic)
upgrading your brakes to bigger ones makes a huge difference. i have a 92 civic vx that had all the original brakes and then i upgraded to the gsr set up which was much better and now just did the type r conversion which is nuts. There is a reason why these nicer cars have bigger brakes on them. To keep your stock stuff in my opinion is dumb if you want your car to stop better. If you are interested i am selling a set of gsr calipers, rotors and hawk hp plus pads. I would sell them to you for $200 as a pkg plus shipping. you would just need to get the knuckle then which arnt very expensive. Email me at timnparts@yahoo.com if your interested.
tangerinebeast
07-22-2011 10:16 AM
