BAD MISFIRE!!!! PLEASE HELP!!
OK heres the deal.... my timing belt came off sending my piston into some open valves. Alright so i pull the head and take care of the bent valves with some spare valve train i have around. replace the timing belt and head gasket. I ran a compression check multiple times and came up with roughly 200psi across the board. Ok so bent valve situation solved. I try to run the car and it idles HELLA choppy. Im throwing codes 71-74 which is random misfire of 1-4 cylinders. i cant figure out why its acting up....it ran PERFECT before the timing belt came off.....i checked timing over and over again....all my marks are dead on and timing is good. If anyone has any suggestions/opinions id love to hear em.
thanks.
Greg
thanks.Greg
sounds like you know what you are doin but are you positive the timing marks are correct?? i would double check with book in hand on that.
is ignition timing correct??
plug wires hooked up correct??
100% positive the timing marks on the cams as well as the main pully are TDC and ignition timing is set adv 16* i belive....anywho i hear it might be fuked up spark plugs.....i dunno what to do....i replaced the cap and rotor today with OEM honda goods. i swapped the wires for a differant set....no differance. im gonna get some new plugs tomarrow....might not help....but it wont hurt either
B18b Axles
Jul 20, 2013 07:08 PM
Y2KCivicSiR
May 9, 2005 09:27 PM
