95 civic, suspension. need help please !!
Old 05-09-2005, 07:45 PM
aandrewcc's Avatar
Default 95 civic, suspension. need help please !!
hi, i have a 95 civic.
i just bought some coilovers for it.. you know those $80 coilovers...
the brand is "Racer Design" ...
i put it on my car.. with stock shocks.
http://www.craigslist.org/eby/car/71635758.html
here is a pix of how the stuff looks like...
hmm.. and i also got some enkei rims for my car..
they are 16inch .. the size of the tires are only 40 ....
i drop my car pretty low..
hardly have a finger space.. from my tires.. to the fenders...
do i need to buy camber kit ??????????
also !!! the main problems is !!!!
my car feel so so so !! bouncy ...
and shity. .
what can i do about to ??
should a buy new ?? shocks ??? like some aftermarket shocks ???
or should I ... do something else to it ???
i also dont know whats the different between .. ground control ?? coilovers ?? spring..
do like spring feel better or ??
i didnt put those pad .. on my coilovers.. now it always make some squeeze noices... when the car bounce.
please help me.. i dont really know alots about car..
please tell me what should i do .. or buy.. or put..
to make my car not that bouncy ??
soo.. when i am on the freeway ... would be ALOT MORE smooth...
becus right now my ride feel really shity.. and i drive alot on freeway too.
also.. how can i get those squeeze noice out ??
am i suppose to put those stock pads on ???
thank you !!
Old 05-09-2005, 07:50 PM
ganjafarmer143's Avatar
i have H&R springs on my car and some kinda bushings and it rides erally good...cant remember the brand of bushings but it could just be that your shocks aren't good
Old 05-09-2005, 07:57 PM
SleepnCiViC's Avatar
man dont try to patch up fix this, you need to restart w/ a whole new better quality setup. save your money, never lower a car on stock shocks (i highly recommend against it) Suspension is the last area you want to be cheap w/ it will cause tons of headaches, and the money you waste to make your shitty setup better, you could have jus bought nice equipment to begin w/. and if your car is that low you've prolly already blown your factory shocks, if not then very close too.
to answer your other questions, ground control is a coilover product company. They are pretty decent product if you match them some after market shocks.
im not sure what you mean by a "spring feeling" when your car goes aver a bump or a dip it should take it then become steady immediatly after that, it should not continue to bounce.
Old 05-09-2005, 08:03 PM
aandrewcc's Avatar
Default Re: (SleepnCiViC)
thanks.. but then,.. could i just buy some good shocks ??? or i need to change my coilovers and stuff too ?
Turbo_y8's Avatar
cheap **** coils= soft spring rate which then = bouncy and you put in on stock shocks, kids you get what you pay for
Old 05-09-2005, 08:06 PM
i would change everything man. when parts work together, one shitty part will always **** up a good part. and you will never get the full potential out of something unless it match properly w/ another componet
Old 05-09-2005, 08:07 PM
civictildeath's Avatar
Default Re: 95 civic, suspension. need help please !! (drewsointoyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewsointoyou &raquo;</TD></TR><TR><TD CLASS="quote">do i need to buy camber kit ?????
to make my car not that bouncy ??</TD></TR></TABLE>
camber kit- depends on how often you want to buy new tires becuase they will wear faster on the inside and will need replacing more without one
ground control is a company
coilovers are adjustable height
springs are like stock suspension
check out my suspension thread in my sig below lots of ideas on what to get
Old 05-09-2005, 08:48 PM
FlatBrokeHatch's Avatar
Default Re: 95 civic, suspension. need help please !! (civictildeath)
Easy solution...buy my GroundControls and KYB AGXs
93gsrcoupe
Suspension & Brakes
26
01-30-2005 11:03 AM
TheConnecticutKid
13
04-05-2004 08:35 AM
Knight2000
09-27-2002 03:40 PM
Andaloro99
08-04-2002 04:52 AM
builtB20turbo
10
07-11-2002 02:44 AM
Quick Reply: 95 civic, suspension. need help please !!
