rear disc brake swap question
my question is, will a '94 integra LS rear disc brake swap on my '99 civic w/ factory 14in HX wheels fit? will there be any room for clearance or will i have to upgrade to a 15in wheels? i prefer not b/c im liking my HX wheels and if im correct LS integras came w/ 14in steelies. iunno lmk wsup all u brake swappin' pro's.
rear brakes fit fine...front wheels will not fit over the brakes will not if u get gsr...i got hx's on my car with gsr rear brake so im SURE!! Good luck with the brake swap
Re: (dc2vu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2vu »</TD></TR><TR><TD CLASS="quote">rear brakes fit fine...front wheels will not fit over the brakes will not if u get gsr...i got hx's on my car with gsr rear brake so im SURE!! Good luck with the brake swap</TD></TR></TABLE>
oh no, im just swapping out the rears from drums to disc brakes. btw is there anything bad im going to be running into, like major or any modifications?? b/c everything i will be needing for this project is coming straight out of a LS teg and my drums will be goin on his teg, so we're literally will be "swapping" our brake set ups. thanks
Re: (dc2vu)
As long as you use your front brakes, you will be fine. I just put some 13" steelies on my friends totaled 97 LS.(in the rear only)
Edit: The only real problem you will run into is the e-brake cables. The e-brake cables are a little short (no big deal). I put the same swap on my 96 coupe and they work great. But if you want the "correct" cables get some of a 99-00 Si. If you ever plan on getting Braided SS lines for the rear discs, get them for a 99-00 Si as well.
Edit 2: Last edit I swear. MAKE SURE YOU USE A FLARE NUT WRENCH FOR THE BRAKE LINES!!!!!!!!!!!!!!!!!!!!!!!
you should be fine bro...if u know enough about what ur doing...its like direct swap over...make sure u get the integra ebrake cables though..uhh nothin major in mods or anything...i had a little issue of getting the brake line out that was about it...stupid clip was in the way i couldnt see cuz of all the dirt that built up
Re: (SOHC4life 96)
k thanks bro, btw i have a 99 sedan, i don't think it'll be any difference in vehicle length. my sis has a 99 coupe and when we park in the garage from front to rear bumper we're exactly the same length.
89dxhunchback
37
01-01-2005 12:07 PM
