not getting fuel
not getting fuel
I got this EG with a JDM H22 in it and its not getting any fuel. i turn the key twice and dont hear the fuel pump.
I checked the main relay and switched it with my cousins car and that wasnt it. i check the fuses and that wasnt it. then i replaced the fuel filter with my cousins EG and still it doesnt work. i put my fuel filter in his car and it works so it wasnt my fuel filter.
so ..... anyone have any idea whats wrong?
Re: not getting fuel (MrEF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrEF8 »</TD></TR><TR><TD CLASS="quote">i turn the key twice and dont hear the fuel pump.</TD></TR></TABLE>
theres your problem. fuel pump is bad or wiring is bad if fuses and relays are good
Re: not getting fuel (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">
theres your problem. fuel pump is bad or wiring is bad if fuses and relays are good</TD></TR></TABLE>
pump isnt bad. i switched pumps with my cousins car and his dont work on my car either and mines works on his. so the pump is good.
how would i check the wiring? would i need one of those screw driver with a light in it and a ground wire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrEF8 »</TD></TR><TR><TD CLASS="quote">would i need one of those screw driver with a light in it and a ground wire?</TD></TR></TABLE>
yeah its called a Test Light or you can use an ohm meter to measure resistance
yeah its called a Test Light or you can use an ohm meter to measure resistance</TD></TR></TABLE>
but which one should light up? because some lights up and soem dont.
you got a diagram by any chance?
EK would be almost the same but not exact. i dont have my EG book with me tonight. its in the sol and sis took it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">EK would be almost the same but not exact. i dont have my EG book with me tonight. its in the sol and sis took it</TD></TR></TABLE>
damn, i was hoping to start her up tonight.
Re: not getting fuel (Lmgrcivic)
no idea if this could be your problem, but i figured id try... does your car have a CKS sensor?? mine came unplugged on my b18c1 and it wouldnt turn on my fuel pump because it didnt see the crank turning.
Re: not getting fuel (greenblurr93)
-fuel pump is good
-main relay is good
-ecu is good
-ground is good
-havnt checked the fuel filter yet but that has nothing to do with the pump not turning on though, right?
so now what?
-main relay is good
-ecu is good
-ground is good
so now what?
Re: not getting fuel (SoOHiGH)
fixed the fuel problem, it ended up being a loose ground.... anyways, it running now, and i offically have 1.4 miles on a brand new engine! thanks for your help guys!
