best cam to put it stock 94 civic hatch.
what is the best cam to use in the stock 1.5L sohc civic hatch. i am auto crossing my car, and i feel it lacks power, and i want to upgrade the cam. Not sure what to look for or go with.
Unceasing Measure
Re: best cam to put it stock 94 civic hatch. (1jdmdude8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmdude8 »</TD></TR><TR><TD CLASS="quote">what is the best cam to use in the stock 1.5L sohc civic hatch. i am auto crossing my car, and i feel it lacks power, and i want to upgrade the cam. Not sure what to look for or go with.</TD></TR></TABLE>
You can put a D16Z6 engine and transmission in your car and remain in the same class (EP) if I remember correctly. Putting a cam in your engine will bump you into modified, gain you maybe 2hp and make you the laughing stock of the M3's and Porsches that play there.
Don't put a cam in your 1.5L engine. It's just not worth it.
Re: best cam to put it stock 94 civic hatch. (Archidictus)
i am allready in sm class. and i am actually beating a lot of the sti's and 240's and some other things, it is just the in the straights and coming out of corners it lacks the torque and pull that i need
If you don't do a whole z6 swap, at least swap the tranny. The Si gearing is more agressive than what you currently have.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmdude8 »</TD></TR><TR><TD CLASS="quote">i am allready in sm class. and i am actually beating a lot of the sti's and 240's and some other things, it is just the in the straights and coming out of corners it lacks the torque and pull that i need</TD></TR></TABLE>
In that case, Gude makes a good one . Seriously though, it's not going to make much of a difference. You'll get a much better result and have a much better platform if you just switch to a Z6. The cam will net you power only with tuning, and after that is said and done, you'll have spent enough to buy the swap
Just something to think about.
Re: best cam to put it stock 94 civic hatch. (EH339)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH339 »</TD></TR><TR><TD CLASS="quote">If you don't do a whole z6 swap, at least swap the tranny. The Si gearing is more agressive than what you currently have.</TD></TR></TABLE>
that i didn't think of, but if i was going to do that, i might at well throw a flywheel and clutch in it as well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Just something to think about.</TD></TR></TABLE>
the only reason i dont want to do a swap it cause it would be awsome to beat people with only running this motor, and i would rather built and race, than swap. i like to see progress, and what i can do with stock motors. I used to do a lot with atv's, but cars seam to be a lot more safe, and i can't afford to get hurt on an atv anymore.
i am in sm, because of suspension, swaybars, tires. and then the most rediculous part of all is because i have no back seats, and taking a whole 16 pounds or so out bumps you into sm
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmdude8 »</TD></TR><TR><TD CLASS="quote">i am in sm, because of suspension, swaybars, tires. and then the most rediculous part of all is because i have no back seats, and taking a whole 16 pounds or so out bumps you into sm</TD></TR></TABLE>
As far as I know, you can remove however much of whatever you want and remain in EP. At least you can here in Ohio...
Re: best cam to put it stock 94 civic hatch. (scuzz)
not for the scca though, otherwise i'd be set. and every run i take is within 9 thousands of each other at the same track, so i have found the limits for my car. maybe it will be that way in pheonix as well, cause i am moving there in 2 weeks
azn_outlaw
10-20-2001 06:44 PM
