rear disc caliper upgrade ????
i just got a set of rear disc for my car, its off a '90 teg, i want to upgrade the caliper and rotor pads, what would be a good caliper to go with and rotor size? thanks
Re: rear disc caliper upgrade ???? (Rash Ej1 SiR)
It's just the rear, leave the caliper and rotor stock. Get the same brand/type of pads for the rear that you get for the front and that should be sufficient.
If you have heavily upgraded front brakes, then get the rear brakes to match your front set. Normally you want to upgrade the front as much as your brakes budget allows, and then upgrade the rear with whatever you have left.
well, i am planning on upgading my front as well, but when i do them, im gonna do the front as well, along with the whole suspension, i just havent upgraded rear disc setup yet.
Re: rear disc caliper upgrade ???? (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp »</TD></TR><TR><TD CLASS="quote">It's just the rear, leave the caliper and rotor stock. Get the same brand/type of pads for the rear that you get for the front and that should be sufficient.
If you have heavily upgraded front brakes, then get the rear brakes to match your front set. Normally you want to upgrade the front as much as your brakes budget allows, and then upgrade the rear with whatever you have left. </TD></TR></TABLE>
eg686
21
04-04-2005 05:07 PM
