Fastbrake upgrade ?s
After searching I found nothing that would be applicable to me here on HT. I went to http://fastbrakes.com/shop/. They have several different kits available for my EG. However I'm running on 15x6.5 Racing Hart CP035 and noticed that some of the 11" brake packages said they will clear some 15" wheels. I was wondering if I'd be ok with 11" rotors or should I get the 10.2" kit to play it safe. Also are the fastbrake packages good or should I go with wilwood.
Re: Fastbrake upgrade ?s (broketuner-egb16a)
it's not necessarily the rotors that will prevent you from using 15" rims, but rather the CALIPERS. 11" rotors were standard for ITRs... and they have stock 15" rims. you should be fine.
Re: Fastbrake upgrade ?s (ADVAN EG2)
i bought the kit but havent put it on yet, tryin to sell them but i contacted fastbrakes and he said all i would need is like a 5mm spacer for the fronts if my rims didnt fit. slips dont fit but curcuit 8's do!
if your intrested in them ill sell them cheap!
Re: Fastbrake upgrade ?s (jdmchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop »</TD></TR><TR><TD CLASS="quote">if your intrested in them ill sell them cheap! </TD></TR></TABLE>
Right now I'm just doing research, on what I can do. If they're still available in a month or two(or whenever I get more $ for parts) I'll take the fronts, I already have rear discs.
wenlyone
08-08-2011 12:37 PM
. o 69 o .
10-29-2004 02:56 AM
