Need Help!!!- Trouble Code 0= ECU. . . how to know if its 0
i purchased a 94 cx w/ b16a in it. . .i got the car for cheap cuz it wouldnt start and i ran a jumper wire in the obd1 plug and when i turn the key to the on position the check engine light comes on like it is goin to start the dtc test but then the light just stays on so does that mean that would be code 0???
when the jumper wire is out of the obd1 plug and i put the key in the on position the dash runs the mil test and the check engine light goes off.
thanks for any help!!!
no doing the jumper thing is not a good way to found out, i would get a diagostic tool to check it the right way, of course the cel might be on because it has a swap in it that common. if doesnt want to crank over you/or start you need to check the possiable "trouble shooting" i suggest buying a haynes manual.
HT Order of Merit
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_civic1 »</TD></TR><TR><TD CLASS="quote">no doing the jumper thing is not a good way to found out, i would get a diagostic tool to check it the right way, of course the cel might be on because it has a swap in it that common. if doesnt want to crank over you/or start you need to check the possiable "trouble shooting" i suggest buying a haynes manual. </TD></TR></TABLE>
The jumper thing works fine. Its a waste of time and money to try and find an OBD1 scanner for a Honda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Egezzy »</TD></TR><TR><TD CLASS="quote">i purchased a 94 cx w/ b16a in it. . .i got the car for cheap cuz it wouldnt start and i ran a jumper wire in the obd1 plug and when i turn the key to the on position the check engine light comes on like it is goin to start the dtc test but then the light just stays on so does that mean that would be code 0???
thanks for any help!!! </TD></TR></TABLE>
And can you tell me WHY your jumping the plug? If you leave that jumper in and start the car, the CEL will stay ON... this mode is useful to check/set ignition timing. Your setup sounds fine to me.
its a waste of money? there only like 50 bucks or so at your local auto zone, i was just saying these because its better to plug up and get all the codes on the scanner, then jumping the wire plug, counting the blinks and looking it up in a book! saves time and effort that all.
the cheap-o crap OBD2 scanners are $50
OBD1 scanners are difficult to find outside honda service bay or really serious mechanics tool box.
Service Jumper not installed = no CEL
Service Jumper installed = solid CEL
sounds like normal operation with no DTCs to me.
what does the car do? (it doesn't start) does it turn over? does it try to run? does it have spark? does it have fuel?
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">
X2
X2
Re: Need Help!!!- Trouble Code 0= ECU. . . how to know if its 0
wow you call yourselves tunres. what he is saying is that when he turns the car to the on position the cel stays on instead of purging the fuel system then shuting off after about 2 seconds. then when he installs the jumper still a constant cel with no blink. any real tech knows this to be a problem with either the main relay, ignition switch, ecu or shorted wiring. good luck im trying to get the same thing fixed on my friends lude
Code 0 is indicated when the CEL remains on steady both with and without the 2P service connector jumped (=problem with ECU power or ground).
For the OP, the CEL turns off with the key on, so there are no CEL codes and the ECU is not detecting any problems (=normal).
wow. back from the dead.
the car at the time actually had a bad ignitor so the car wouldnt start plus the condition above. with it being my first swapped car i kind of freaked about the cel being on. once i replaced the ignitor the car ran perfect expect for a bad iacv idle. lol.
hunter fitch
Engine Management and Tuning
02-01-2019 11:12 AM
SmogKing
08-03-2006 12:48 PM
Egezzy
05-06-2006 05:53 AM
