FITV
Re: FITV (1slowhatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhatchie »</TD></TR><TR><TD CLASS="quote">why are you cleaning your fitv? is your car reving up and down? </TD></TR></TABLE>
+1
To answer your question: No, you don't have to take off the IM, therefore, no need to replace gasket
+1
Re: FITV (importtuner07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 »</TD></TR><TR><TD CLASS="quote">if i clean the FITV would i need to replace the intake manifold gasket? thanks for your help</TD></TR></TABLE>
your probably thinking of your throttle body gasket,i would cause when you take it off most likely the gasket would get messed up.
its when i start it it ideals like at 500 or 600 until i rev it then it will ideal kinda right but ideal up and down and on the fourm the person takes off the IM so i thought i would but could it runin like that because my spark plugs are fouled out from gettin water in my intake. thanks again for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner07 »</TD></TR><TR><TD CLASS="quote">its when i start it it ideals like at 500 or 600 until i rev it then it will ideal kinda right but ideal up and down and on the fourm the person takes off the IM so i thought i would but could it runin like that because my spark plugs are fouled out from gettin water in my intake. thanks again for any help</TD></TR></TABLE>
I did not really understand what you said
BTW it's "idle" not "ideal"
From what I did gather you're not having problems with your FITV. You need to look into your IACV
