cluster
cluster
i have a 95 dx coupe and i want a cluster that has a tack will a 95 ex cluster work? do i need anything special to hook up the tack part of the project? other then the tack will the rest plug n play??
Re: cluster (potential)
im not sure bout civics but i do no if u find one from the same body style car the tach also plug and play your wiring harness has it wired in all ready u just dont have the tach in your cluster so find one that bolts right in and just plug and go
Yes, a 95 EX cluster will be a direct fit. You can also use a 92-95 Si cluster. Nothing is really required other than a screwdriver and the rest is pretty much plug and play. If you don't know how to remove your dash, here's a thread that explains how.
https://honda-tech.com/zerothread?id=661308
**The thread is originally intended to show people how to install amber/red dash lighting but if you read a bit, it'll show you how to take out your dash.
Stuominous
04-22-2014 09:08 PM
TreyA
09-10-2013 07:00 PM
