s20 tranny making noise
every time i put my car in first and start to go it sounds like im in reverse...wtf i dont understand. help please also its making a noise when i decelrate like a waaaana na na na help pissin me off.
Re: s20 tranny making noise (v8killa91)
From the sound of your symptoms it sounds like its your input shaft bearing is going bad ( i have the same problem now), which is a common problem with honda trannies. BauleyCivic has a thread https://honda-tech.com/zerothread?id=596873 on how to change out this bearing.
Re: s20 tranny making noise (turboxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboxsi »</TD></TR><TR><TD CLASS="quote">From the sound of your symptoms it sounds like its your input shaft bearing is going bad ( i have the same problem now), which is a common problem with honda trannies. BauleyCivic has a thread https://honda-tech.com/zerothread?id=596873 on how to change out this bearing.</TD></TR></TABLE>
Yup. The input shaft bearing is going. I had that problem a while back. While you're in there you might as well change out the main shaft bearing because they usually go out at the same time.
not that kinda noise. its in first and when decelrating between gears. like wha=en i push the clutch in then slowly let it out it whinessoon as it engages bam it goses away. i dont understand? help
