i have a 95 vx with a d16z6 motor in it if i use a z6 harness will it b plug n play for vtec??
hi all im not to sure if i have to add vtec too my ecu harness or can i plug in a z6 harness, well heres what i have,
i have a 95 vx with a d16z6 motor in it. if i use a z6 harness will it b plug n play for vtec?? or will i have to add it at the ecu still? thanks.
Re: i have a 95 vx with a d16z6 motor in it if i use a z6 harness will it b plug n play for vtec?? (
Since the Vx is also a Vtec engine, it should be plug and play because it should have the necessary provisions for the pressure switch and solenoid in the harness. Im not sure if theyd go to the correct pins in a P28 ecu though.
You can use the stock VX harness. The only thing you would have to change is the o2 sensor to a 4-wire o2 sensor since VX's are 5-wires.
ok kool thanks. when i go get my car tuned ill just get my o2 disabled. thanks for the info.
krysted9354
20
12-14-2008 02:31 PM
SlaMMedB16
02-25-2008 12:56 PM
kajay1972
09-08-2007 07:35 AM
88CiViC_DX
07-07-2003 04:21 PM
